you dont need to change anything in the BIOS or anything like that, only headers that need to be plugged into the motherboard are those for the power button and that stuff, boot and install and OS and then download the latest NVIDIA drivers and install them and then you have your PC
Builds:
https://linustechtips.com/topic/648815-post-built-setup/#findComment-8344612
You only need to mess with the BIOS if you are overclocking, and for that you should google for articles/videos on overclocking an i5-6600K.
Any overclocking should only be done after you have the system up and running at default settings. The BIOS will detect the components installed (CPU, etc) and set default values at startup.
There's probably no jumpers on the motherboard. If there are, RTFM (consult the manual).
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/648815-post-built-setup/#findComment-8344620
IK what RTFM means
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/648815-post-built-setup/#findComment-8345159
