Hey guys
have recently noticed that my second pc has become so slow that what it used to be and have narrowed it down to my sata being nerfed and with this i mean its not performing to maximum potential
my sata mode in bios is on AHCI mode and Hard drives active mode is on MWDMA2..
so i changd my sata mode to enhanced IDE with drives then running on UDMA5 mode and the speed and performance is exactly the same as MWDMA2
even went as far installing a pcie sata controller card and booted windows from that with drives running on UDMA6 mode and still no change in performance what so ever
the hard drive active time stays on 100% until fully booted after a few minutes it wil go back to normal % but during this period the read speed is between 3mbs to 5mbs
i have now tried everything new OS and still the same cant crack this problem
the actual AIDA64 Read Suite runs perfect with performance at expected levels
it was working fin before up until now
OS is windows 10
Asus P5E Deluxe  ( Rampage Formula Bios Mod)
Intel Q9505
https://linustechtips.com/topic/647714-unsolvable-sata-problem/
Have you tried another cable?
Also it depends on what requests are given to the hard drive. If the OS is pounding the drive with lots of requests, storage performance chokes no matter what kind it is. Seeing how you say AID64 runs are fine, I suspect this is what's going on.
https://linustechtips.com/topic/647714-unsolvable-sata-problem/#findComment-8332798
Maybe I'm starting from too a basic level, but if performance decreased over time: is it (de)fragmented (assuming it's an HDD)? Or with "installing new OS" you mean you wiped that drive and started from zero (I assumed you boot from a different drive)?
https://linustechtips.com/topic/647714-unsolvable-sata-problem/#findComment-8332799
the common denominator here is the HDD.
when you say maximum potential, what are you expecting, vs what are you achieving?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/647714-unsolvable-sata-problem/#findComment-8332801
yes have tried another cable still does the same , the OS boots extremely slow an does things slow but anything else works like it should in terms of load speed etc
how can i see what is bombarding the drive with requests the event viewer does not tell me much
did also drive other drives basically does the same
now i can format my system again how ever before i do want to rule out any other possible cuases
https://linustechtips.com/topic/647714-unsolvable-sata-problem/#findComment-8332869
