PSU Making a crazy sound??
Go to solution Solved by STRMfrmXMN,
2 minutes ago, BenKavanagh said:
My new psu (1month old), the CX450M just randomly started making a weird very loud sound. Sounded really bad. I was just playing some games, then closed the game to go on the internet when it randomly made this noise. I restarted my pc then after a couple more minutes the sound came back. What do i do now? Is it broken?IMG_3417.MOV
Your fan sounds like it went haywire. RMA to Corsair.
Also, for those afraid of downloading a .MOV file rather than an MP3 or the like, the file is safe.
https://linustechtips.com/topic/647467-psu-making-a-crazy-sound/
https://linustechtips.com/topic/647467-psu-making-a-crazy-sound/#findComment-8330240
Sounds like the fan is rubbing against something but definitely contact Corsair.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/647467-psu-making-a-crazy-sound/#findComment-8330243
I know I probably shouldn't. But can anything go wrong if keep using my pc?
https://linustechtips.com/topic/647467-psu-making-a-crazy-sound/#findComment-8330244
I wouldn't try to find out for myself, but I think it's just the fan. Make sure the thing is breathing well enough and don't stress your GPU and you'll probably be fine.
https://linustechtips.com/topic/647467-psu-making-a-crazy-sound/#findComment-8330251
