What should I do my hp laptop did what to boot because of an error so I tried recover tool in windows but it says windows is locks on driver unlock it first had no way off unlocking it so I did a factory reset but my power went out no it just does this
https://linustechtips.com/topic/647414-help/
If the laptop has a recovery partition you will have to try to use the boot menu to load into that, if not then sadly you may have to get a disk somehow and do a complete wipe.
Rainbow Barf
CPU: i7-12700K GPU: RX 6800 XT RAM: 64GB DDR4 Storage: 2TB NVME SSD RAID - 1TBx2 NVME SSD - 8TB HDD
Lenovo Legion Pro 5i
CPU: i7-12700H GPU: RTX 3070 Ti RAM: 32GB DDR5 Storage: 1TB + 1TB SSDs
https://linustechtips.com/topic/647414-help/#findComment-8329765
If power went out while it was resetting then your OS is corrupted.
You need a 4GB or larger USB drive, and another working PC, and you can reinstall windows like this: http://www.howtogeek.com/224342/how-to-clean-install-windows-10/
https://linustechtips.com/topic/647414-help/#findComment-8329766
you will have to reinstall windows manually using a USB drive or a DVD ROM does your laptop have a windows sticker with numbers undernieth it and what version did it have once I know what version of windows it had and you can find the sticker with the numbers (which is known as a windows key)
here's a example of what the sticker should look like and the key is used for microsoft to know what PC that windows copy was used on
once you find the key just tell me what version of windows it had like windows 7, windows 8, or windows 10, and then tell me if you had the home version or pro version of windows it would usually say it on the sticker on the bottom of the laptop where the windows key would be if you look at the example picture I put up you can see it had Windows 7 PRO
PS don't post a picture of the windows sticker on this page just tell me if it has it or not on the laptop
And after you find the sticker and tell me what version of windows it had I'll then walk you through on how to fix it step by step
https://linustechtips.com/topic/647414-help/#findComment-8329782
Yeah it does have a recover partition second part of the drive will it still be still be there
https://linustechtips.com/topic/647414-help/#findComment-8329800
3 minutes ago, yesman said:
Would I still have the back up of the windows on the second partition of the hard driver tho
if your windows is corropted it's going to be extremely hard to get the files back because windows locks down your files on the drive with a bunch of security stuff
https://linustechtips.com/topic/647414-help/#findComment-8329811
No it doesn't have a sticker the only way how I could off seen the code is with the hp software on the laptop but can't get on
https://linustechtips.com/topic/647414-help/#findComment-8329840
2 minutes ago, yesman said:
Would the second partition of the drive where the back up would tht be there
I don't know if it would I'm mainly used to working on custom built PCs and when repairing laptops and prebuilts I just format the whole drive after I back up all the files if there was any files to back up
and I just do a full reinstall which microsoft made it easier and easier to do with a windows disk or USB drive with the windows installer I can show you where you can get a windows key for about $30 USD and you  can use that to install windows 10 onto the laptop
https://linustechtips.com/topic/647414-help/#findComment-8329885
Yeah please where can you get a windows key from
https://linustechtips.com/topic/647414-help/#findComment-8332027
Just choose which one you want Windows 10 Home or Windows 10 Pro
Windows 10 Pro:
https://www.kinguin.net/category/19429/windows-10-professional-oem-key/
Windows 10 Home:
https://www.kinguin.net/category/22175/windows-10-home-oem-key/
After you buy the key you can download the Windows 10 USB Drive installer from Microsoft with this link: https://www.microsoft.com/en-us/software-download/windows10/
to install the installer to a USB drive you need a old USB flash drive that is 4gb or larger and it should be fairly easy to get the installer onto the flash drive
https://linustechtips.com/topic/647414-help/#findComment-8333853
