Yes, yes and yes.
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
https://linustechtips.com/topic/646370-thermal-paste-cleaning/#findComment-8317817
Yes and yes.
It's best practice to clean off both the cooler and CPU itself, as otherwise you just have old thermal paste gunk on one of them. If you are re-using either you want it to be clean too. Alcohol and coffee filters will work fine. Coffee filters are recommended because they don't fall apart, like other sort of paper towels would and they also don't leave fibers behind.
https://linustechtips.com/topic/646370-thermal-paste-cleaning/#findComment-8317821
