Hi guys,
I went to try and overclock my 4790k on my MSI Z97-G45 Gaming Motherboard. Cooled by NZXT Kraken x61
Now on to my problem.
When i set any vCore voltage and run stress tests Cpu-Z and OCCT show 1.3 volts and above. I set my voltage to 1.225 in override + offset mode (+0.050v) but the voltage always goes above 1.3 volts. Changing the mode to Override or Adaptive doesnt help and there is no "manual mode" on this motherboard. I can set the VCCIN and Ring voltage and it works fine but i cant get it to work with the core clock. This gets me to above 85°C in under 5 minutes...
Will try and upload a screenshot of my settings later.
Edit: The multiplier is x46
Edit#2: Updated the BIOS, did another CMOS flash and it still immedeatly spikes to 1.36 volts...
https://linustechtips.com/topic/645351-4790k-vcore-voltage-not-adjustable/
try using Intel Extreme Tuner, might help with your problem, or atleast to find what is causing your problem because you dont need to constantly go into the BIOS
Builds:
23 minutes ago, bLaInEx said:
Hi guys,
reset your bios to default and try your overclock again?
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
I did it from scratch
Edit: Uninstalled Intel Extreme Tuning Utility, wich was installed when i first build the PC and did a CMOS flash. Didn't help..
