Intel i5-6600K
Asus Maximus VIII Hero Alpha
Noctua NH-D15
Intel 730 Series 480GB SSD
Kingston HyperX Fury 2400Mhz 2*8GB
GTX 1070 Founders Ed.
Corsair Carbide 400C
Corsair CX550M PSU
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
https://linustechtips.com/topic/645210-comment-on-my-build/
It's within my budget, just wondering if you have any comments, its for some gaming, video editing etc.. already have peripherals, monitors etc
https://linustechtips.com/topic/645210-comment-on-my-build/#findComment-8305773
CX PSU ... meh
Also I wouldn't buy Founders Edition. Get some other brand with 2 fans :)
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/645210-comment-on-my-build/#findComment-8305776
1 minute ago, Simon771 said:
CX PSU ... meh
The PSU isnt really that important for me lol, and I might be upgrading to a custom loop in the future, hence the founder's edition, plus its a little cheaper then the other cards
https://linustechtips.com/topic/645210-comment-on-my-build/#findComment-8305787
The PSU NEEDS to be important to you. It's what powers everything, if you cheap out and buy crap then its more likely your system will die.
https://linustechtips.com/topic/645210-comment-on-my-build/#findComment-8305799
3 minutes ago, Simon771 said:
CX PSU ... meh
The CX550M is decent unlike the others
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/645210-comment-on-my-build/#findComment-8305802
In that case I agree with your about GPU. if you can get Founders Edition for same or even lower price, just get that if you plan to use waterblock on it.
But PSU ... you should care about it. Get something like RM650x. It's like 100$ only and it's great quality.
You don't want PSu to fry your components right? CX is bad quality.
WD My Cloud 4TB
https://linustechtips.com/topic/645210-comment-on-my-build/#findComment-8305820
This is the CX 550M, the new corsair cx greys, not the older cx greens. Tier 3 in the psu tier list, its fine for his build.
https://linustechtips.com/topic/645210-comment-on-my-build/#findComment-8305851
Oh my bad.
Looked it up and I see that this PSU isn't bad at all.
So everything seems fine with that build :)
WD My Cloud 4TB
https://linustechtips.com/topic/645210-comment-on-my-build/#findComment-8305877
Thanks for the feedback everyone :)
https://linustechtips.com/topic/645210-comment-on-my-build/#findComment-8305932
