what CPU, Case and do you want to OC?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/645158-air-vs-aio/#findComment-8305333
3 minutes ago, Carnage. said:
http://au.pcpartpicker.com/list/FgbYgL
thats my build there
wow lol. Get a new Motherboard dude.
I'd say a nice Little aircooler like the Hyper 212 Evo and you are good to go.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/645158-air-vs-aio/#findComment-8305350
Air: http://au.pcpartpicker.com/product/4vzv6h/noctua-cpu-cooler-nhd15 or http://au.pcpartpicker.com/product/9bFPxr/be-quiet-cpu-cooler-bk019
Water: http://au.pcpartpicker.com/product/CrDzK8/corsair-cpu-cooler-cw9060025ww
(These are your options for high ocs)
Edit: Realised you have a h170 board so as @FloRolf said get a 212 evo
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/645158-air-vs-aio/#findComment-8305352
Change eithrr CPU or mobo. Its waste of money to have K-chip on chipset which doesn't support OC'ing.
Whats your budget? Unless you aim for higher OC or are going for looks, AIO is waste of money. Dual tower heatsinks will be about same performance with 240mm rads. Bigger single towers will beat 120mm rads easy. While being considerably cheaper.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/645158-air-vs-aio/#findComment-8305447
what sort of mobo do you suggest i get
https://linustechtips.com/topic/645158-air-vs-aio/#findComment-8305612
anything less than 240mm rad basically performs like an air cool but with a higher cost. my 8350 has h100i and with a mild 4.5 GHz oc @ 1.4v it still gets rather warm.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/645158-air-vs-aio/#findComment-8305673
25 minutes ago, Carnage. said:
what if i dont want to OC
If you don't want ever, get non-K CPU. Its same thing except multiplier will be locked. You save $50 and get stock cooler with it. With that $50 you can get Pure Rock which is among best cheap air coolers.
https://linustechtips.com/topic/645158-air-vs-aio/#findComment-8306139
