The i7 will do better for video editing and the extra threads help for streaming IIRC. You can get a xeon if its cheaper.
https://linustechtips.com/topic/644716-i-need-help/#findComment-8300230
The i7 will help with streaming and video editing so if you can spent the extra money get that.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/644716-i-need-help/#findComment-8300232
Just now, Cube_Dragon137 said:
Do you have a budget, any other specs of the system?
Gaming and Streaming, i5 would be fine, but the Hyperthreading of the i7 will be helpful for processing the video
for the whole build, i dont want to spend more than $2000
http://au.pcpartpicker.com/list/T9vQD8  that's it so far
https://linustechtips.com/topic/644716-i-need-help/#findComment-8300249
1 minute ago, Carnage. said:
are xeon better than the i7
Same in performance, maybe just with slightly higher/lower clock speeds, but nothing that'll really affect performance much.
https://linustechtips.com/topic/644716-i-need-help/#findComment-8300251
