PSU and Case
Go to solution Solved by HKZeroFive,
Just now, A User said:
Much better, although it's a bit overkill if you're not planning on Crossfiring or SLI'ing.
Yes, it does. Although I would get a different power supply since the NEX series are quite mediocre.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/644638-psu-and-case/#findComment-8299403
It will. It's a standard PSU. Although I won't recommend this PSU. The G2/GS/P2 will be do better
https://linustechtips.com/topic/644638-psu-and-case/#findComment-8299404
Corsair RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply Is this better?
https://linustechtips.com/topic/644638-psu-and-case/#findComment-8299414
https://linustechtips.com/topic/644638-psu-and-case/#findComment-8299416
