How long will it survive?
Go to solution Solved by SageOfSpice,
Just now, WildCAt said:
Is it THAT bad? :D ^^"
I wouldn't say so. Run some tests on it, see how it holds data, check it's integrity, speeds, ect. If it all comes back clean, it'll probably be alright. The power on count is really quite absurd, so either that's some sort of error, there was an issue with the computer it was plugged into, or if it could be the drive itself. If the tests come back clean, I'd say it's good enough to store non-essential things on. Game files, ect.
Hi! ^^
I've just bought and installed 2 "new" used HDDs
Samsung SP1603C 160 GB
Seagate ST3160815AS 160 GB
They were quite cheap, so I've bought them, at least no rellocated soctors ^^""
One will be for Linux, other for misc. storage
Samsung seems to be OK, despite 4+ years of work
The question is:
How the hell Seagate is so beat up and how long it will live? Can I trust it at all? :D 'Cause motherboard warned me, "better you remove this sh*t" and Windows suggested me to make backup :D
https://linustechtips.com/topic/644217-how-long-will-it-survive/
dont trust the seagate.
the samsung is better than my hdd :P
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/644217-how-long-will-it-survive/#findComment-8294970
Wow. Based on those figures, that drive was powered up and powered down every 13 minutes over the span of 2 years.
No wonder it's not happy.
S.M.A.R.T isn't saying it's bad though, it's just saying that it's passed it's expiry date.
https://linustechtips.com/topic/644217-how-long-will-it-survive/#findComment-8295003
Wow, where did you get a drive like that that was turned on almost 90000 times? loool
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/644217-how-long-will-it-survive/#findComment-8295004
Just bought from a random 51 year old man :D
He's not company or organisation, just a random guy, I have no idea where he got them)
He was also selling IDE drives and some more SATA drives)
https://linustechtips.com/topic/644217-how-long-will-it-survive/#findComment-8295036
I would not trust the Seagate with anything.
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
https://linustechtips.com/topic/644217-how-long-will-it-survive/#findComment-8295063
https://linustechtips.com/topic/644217-how-long-will-it-survive/#findComment-8295066
implying game files are non-essential....
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/644217-how-long-will-it-survive/#findComment-8295080
