CASE WITH USB 3.1 Headers
Go to solution Solved by Biggerboot,
Referring to your original post, there aren't that many (if any) entry level cases with USB 3.1 (type c) on the front.  Typically 3.0 is fine for the front port, and is what's normally included.  Any devices that you may want plugged into a 3.1 to take advantage of the high bandwidth, you'll probably want plugged in directory to your motherboard.
As for finding a cheap case:
You could try a cheaper brand like Apevia, DIYPC, Raidmax, etc.  You can find roomy enough cases on the low end, but typically they'll cheap out on thickness and quality of the metal, included fans, paint, etc.  Check reviews, because they can have their good models and bad models.
I agree with 007 that the Source is really your best option on a budget.  There's also the Corsair Carbide Spec-02 and Thermaltake h22 at around the same price if you are interested in a side window.  You don't want to go super cheap on the case when you already have really high end components  And if you're already bothering with a gtx 1080, what's a little extra for your case and psu? They are pretty important and commonly underestimated in the build.
Power supply wise, absolute cheapest you want to go is an evga b, but the new Corsair CXM (450/550/650) or a Seasonic s12ii will do you better with a 5 year warranty to boot.
Hey guys my friend wants to buy a new custom pc and hence asked me to make a configuration . I made one but is still lacking a good case with usb 3.1 . Please guys help me . Also mention a good budget power supply for the build
Code Name : Blood Red
CPU>> Intel Core I5 6500
GPU>> GTX 1080
MOBO> ASUS Z170 PRO GAMING
HDD>> Seagate Barracuda ST31000528AS 1TB 7200RPM
RAM>> GSKILL Ripjaws-V 2x4GB DDR4 SDRAM
SSD>> Samsung 750 EVO 120 GB
DVD>> LG Internal DVD Burner
Thanks in advance guys ;)
https://linustechtips.com/topic/643228-case-with-usb-31-headers/
CPU>> Intel Core I5 6600K
GPU>> GTX 1080
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284671
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284687
On 8/14/2016 at 8:52 PM, 007agentHP said:
Do u know any of cooler master's
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284770
i dont trust any cooler master psus (killed my father's old PC)
and it depends on the case. which one?
Rigs I've Built
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284778
well not the psu . the f***ing case . I cant find one after googling so many times
1. dont be rude, you said if i knew of any cooler masters. you never specified either PSU or case.
2. a good one i know of is cooler master master case 5
Rigs I've Built
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284794
well i just couldnt control it cuz its maddening . I just searched for like hours now . But isnt a mastercase too expensive . I want an inexpensive one from cooler master , antec , etc
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284800
well a inexpensive case could be the
cooler master n600
corsair 200r
NZXT source 210 Elite
all fine cases
Rigs I've Built
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284807
dont u have something more inexpensive
well going under the NZXT Source 210 Elite is really too low for a case. going under and you will probably have shody cooling and cable management.
Rigs I've Built
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284819
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284908
I agree with 007 that the Source is really your best option on a budget.  There's also the Corsair Carbide Spec-02 and Thermaltake h22, around the same price, and if you are interested in a side window.  You don't want to go super cheap on the case when you already have really high end components  And if you're already bothering with a gtx 1080, what's a little extra for your case and psu? They are pretty important and commonly underestimated in the build.
Power supply wise, absolute cheapest you want to go is an evga b2, but the new Corsair CXM (450/550/650) or a Seasonic s12ii will do you better with a 5 year warranty to boot.
well its a typo that GTX 1080 . He is going for the gtx 1060 and has a budget of below 100 USD left with him
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284922
Got it.
I'd say go with this for your last $100: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139146&cm_re=evga_500b-_-17-139-146-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146102&cm_re=nzxt_source-_-11-146-102-_-Product
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284936
On 8/14/2016 at 9:52 PM, Biggerboot said:
well the case is bit outof his budget
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284944
You could try this enermax: http://www.newegg.com/Product/Product.aspx?Item=N82E16811124166&ignorebbr=1
I'm not particularly keen on enermax cases, but this one has good reviews.
I've also used the Tesseract, which has sorta flimsy front panel guards, but it's not bad at the price (decent size/airflow):
http://www.newegg.com/Product/Product.aspx?item=N82E16811853004
That's all I got.  And now I've lost cred for suggesting such cheap cases. :P
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284968
I've also used the Tesseract, which has sorta flimsy front panel guards, but it's not bad at the price (decent size):
but none of them has usb 3.1
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284973
There are literally no budget mid towers with 3.1.  3.0 maybe, but not cheaper than ~$40.
http://pcpartpicker.com/products/case/#u=1
Also I was thinking of the Tesseract SW.  My bad.
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284981
OK thanks . R u sure there are none
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284987
Yep.  Unless you start looking at micro towers (which won't fit your motherboard).  Cases are tough to really get that cheap because of shipping cost.
Honestly USB 3.0 speeds rarely get reached unless you have an external SSD you plan on using, and your motherboard will still have the 3.1 port.  Just something to keep in mind.
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8284998
Well yeah he has an SSD and will the Mobo be able to utilize its usb 3.1 at least in the back ??? and will it allow the use of usb 3.0 in the front ???
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8285006
Yeah the usb 3.1 will be in the back of the mobo.  The front panel will be whatever the case allows (2.0 or 3.0).
https://linustechtips.com/topic/643228-case-with-usb-31-headers/#findComment-8285012
