CASE WITH USB 3.1 Headers
Go to solution Solved by Biggerboot,
Referring to your original post, there aren't that many (if any) entry level cases with USB 3.1 (type c) on the front.  Typically 3.0 is fine for the front port, and is what's normally included.  Any devices that you may want plugged into a 3.1 to take advantage of the high bandwidth, you'll probably want plugged in directory to your motherboard.
As for finding a cheap case:
You could try a cheaper brand like Apevia, DIYPC, Raidmax, etc.  You can find roomy enough cases on the low end, but typically they'll cheap out on thickness and quality of the metal, included fans, paint, etc.  Check reviews, because they can have their good models and bad models.
I agree with 007 that the Source is really your best option on a budget.  There's also the Corsair Carbide Spec-02 and Thermaltake h22 at around the same price if you are interested in a side window.  You don't want to go super cheap on the case when you already have really high end components  And if you're already bothering with a gtx 1080, what's a little extra for your case and psu? They are pretty important and commonly underestimated in the build.
Power supply wise, absolute cheapest you want to go is an evga b, but the new Corsair CXM (450/550/650) or a Seasonic s12ii will do you better with a 5 year warranty to boot.
2 hours ago, Runelight said:
Hey guys my friend wants to buy a new custom pc and hence asked me to make a configuration . I made one but is still lacking a good case with usb 3.1 . Please guys help me . Also mention a good budget power supply for the build
Code Name : Blood Red
CPU>> Intel Core I5 6500
GPU>> GTX 1080
MOBO> ASUS Z170 PRO GAMING
HDD>> Seagate Barracuda ST31000528AS 1TB 7200RPM
RAM>> GSKILL Ripjaws-V 2x4GB DDR4 SDRAM
SSD>> Samsung 750 EVO 120 GB
DVD>> LG Internal DVD Burner
Thanks in advance guys ;)
check this.
http://mdcomputers.in/thermaltake-mid-tower-cabinet-atx-versa-n25-black-with-transparent-side-panel.html
found a great case for the price .... its hard to find good cabinets in india ?? ..... there's also thermaltake versa n26 which is same from interior just diff. front panel.
6 hours ago, Runelight said:
dont u have something more inexpensive
A Source 210 doesn't even have USB 3.0... how come you can't spend more on a case if you're looking for something with USB 3.1?
