Hello! My name is Finup, I am a gamer and youtuber. I've had a GTX 970 since the begging of the summer and it RANDOMLY just stopped working yesturday, read more for detail!
So... the graphics card is a GTX 970 Strix and 2 days ago I went to play rocket league with my friend, I started up rocket league and then went to change my display setting and once I hit *SAVED* my BOTH of my screens went black and didnt detenct the vga or dvi. Usually I would just restart my PC and it would be fixed (happened 2 times before) but this time it did not get fixed, it just wont display anything on the screen with my graphic card.
Step 2: I tried out my motherboard (cpu intel i7 4700 3.6ghz) and that is displaying shizz on my screen.
Step 3: I went back on my Graphic card and then fan is running, the white light is on and it is being powered. I tried moving it to a different slot on my motherboard and it made no difference.
My graphics card is fully updated and has been working for the past months.... any help please!!!! :(
https://linustechtips.com/topic/642565-gtx-970-not-working-help/
Rma it.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/642565-gtx-970-not-working-help/#findComment-8278139
3 hours ago, Finup said:
I would but I dont think I still have the box O_o
Well that´s bad, always keep the box as long as the warenty is still in place
CPU: AMD Ryzen 9 5950X PBO GPU: Asus Strix RTX 3090 OC Mobo: Gigabyte X570 Aorus Master RAM: 32GB G.Skill Trident Z RGB 3600Mhz CL17
CPU Cooler: Corsair H150i Capillex Storage: Samsung 980 Pro and 970 Evo 1TB Samsung 860 EVO 1TB Crucial MX300 525GB WD Black 2TB PSU: Corsair HX1000 Case: Corsair 500D SE RGB 6x LL120
https://linustechtips.com/topic/642565-gtx-970-not-working-help/#findComment-8278840
Usually RMA doesn't require retail box. I sent my GTX 770 away to Zotac without the retail box, they didn't care.
It's dead bro. It was showing its signs in those 2 prior times but now it's prolly dead.
My 8800 GT was doing funny things before I couldn't take it anymore. It was shutting down my system.
https://linustechtips.com/topic/642565-gtx-970-not-working-help/#findComment-8278872
7 hours ago, Kc7vwc said:
Are other games working? My laptop had a similar issue with Rocket league. Certain quality settings just result in blank screen. Can you hear in game audio while the screen is out?
All the games work because they are running off my pc? Its just my graphics card isnt displaying **ANYTHING* to my screen
https://linustechtips.com/topic/642565-gtx-970-not-working-help/#findComment-8280124
