GTX 1080 Problems - Please Help ;-;
Solved by ShadyOrb09,
Okay, the problem is fixed now, from what I can tell so far. The problem was actually my CPU, but not because it was bottlenecking it was because the CPU was running 55C idle, which is horrible, and would go up even higher when under load and started to throttle. Anyways, so happy and excited to finally play a damn game. Thanks for your help dude.
The two things that solved the problem:
1) Changing thermal paste/reapplying it.
2) Updating BIOs to the current version.
