Some of my games like League of Legends on the Razer Blade uses the integrated graphics when on battery, and uses the 970M when charging.
Other games like Crysis uses the 970M all the times.
I tried everything that I found on google, I changed the settings in both the NVIDIA control panel and the Intel Graphics 530 control panel, still didn't work
Does any of you guys know what is going on?
https://linustechtips.com/topic/642179-razer-blade-14-2016-graphics-problems/
Its probably just using the GPU it needs to, since Crysis is much more demanding than League and cant run off the iGPU. Also most likely a power saving feature
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
Doesn't Razer have a software managing that kind of things for their PC that may overwrite Windows/Nvidia settings ? MSI has that kind of stuff in there software where you can tell your laptop when to use the iGPU or the dGPU
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
Just turn off automatic graphics switching if you want the 970m to run always.
Add LoL to Nvidia's control panel and force it to use the dGPU.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
Yep, it's in the BIOS. It's called thermal shutdown and downclocking due to excessive heat.
THAT BURN
Laptop Main
8 hours ago, Pendragon said:
THAT BURN
Erm, is this supposed to be a pun of some sort?
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
BURN THE HERE... oh wait, the Blade has that taken care of :P
