Hi all,
Been taking a look at a relatives PC that keeps crashing whenever they close a game or program the pc stays on but screen goes off and says no signal to start with I thought it must be a GPU issue but I have put it in another pc ran various benchmarks including furmark and it ran completely fine.
I've tried a different PSU and Ram but still no luck
Now I am thinking motherboard? could this be the cause sometimes the pc will power on and then straight off again. any ideas will be appreciated.
Custom PC:
Intel Core i7 5960X GTX1080 Strix | 64gb 2400mhz DDR4 Corsair Vengeance Ram | Samsung S951 256gb M.2 | 4TB WD Blue SSHD | EVGA Supernova G2 1300watt PSU | Acer XB270HU | Corsair K95 RGB | Corsair M65 RGB |
https://linustechtips.com/topic/641929-pc-crash-issue-after-closing-programs/
Very likely RAM, sounds like on of the DIMMs is bad, run MEMTEST.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
I will do that tomorrow then :) is there anything else that could cause this kind of issue. Basically he closes a game and then 30 seconds after closing the signal to the monitor will go completely. (Tested GPU on another PC didn't have same issue)
Custom PC:
Unless the PC is overheating (which it doesn't sound like it is) than I see nothing else being a more probable cause. The only thing I can think of that would fix the issue would be to replace the RAM which should be very inexpensive for like 8GB's of RAM it'll cost like $20.
I have a spare kit in my box of spare pc parts lol it's only a 1066mhz 8gb ddr3 kit but will do to test if it's the ram before I tell him to go purchase some new ram
Custom PC:
Could be a driver issue. They do get corrupted sometimes. If you haven't already, I'd use ddu to uninstall the current drivers then reinstall the latest whql drivers
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
I completely fresh installed windows 10 on a new hard drive with drivers because the old hard drive had bad sectors
Custom PC:
fair enough, well i have nothing further to add then good luck.
My rig:
Tested a different kit of ram from a working PC and it still crashes so now all that is left is the motherboard or CPU but I would have thought if it was the CPU it wouldn't even turn on?
Custom PC:
