It'll all work together.  Don't know if I'd make the same choices.  I'd look to do 2x8gb, and go with a M.2 PCI-E SSD instead of that Intel thing.  HGST 7200rpm drive instead of that Seagate, and probably a pair of them if you care about data integrity.
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8260347
1 minute ago, frozeNNN said:
Yes it will work. But that psu is way too overkill
I was kinda thinking about oc in future, so I want to be prepared, you know. Thanks! :)
I'd say that 4x4 looks better than 2x8. Interesting point about the storages, I'll surely look into that before buying! Thank you as well! :3
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8260382
650W is more than enough..
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8260401
Give me 2 seconds and Ill make that better
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8260407
PCPartPicker part list: http://pcpartpicker.com/list/hdb8JV
Price breakdown by merchant: http://pcpartpicker.com/list/hdb8JV/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($114.49 @ SuperBiiz)
Motherboard: MSI X99A SLI PLUS ATX LGA2011-3 Motherboard  ($219.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($76.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($157.95 @ Amazon)
Storage: Western Digital BLACK SERIES 4TB 3.5" 7200RPM Internal Hard Drive  ($196.99 @ B&H)
Video Card: Gigabyte GeForce GTX 1070 8GB G1 Gaming Video Card  ($429.00 @ B&H)
Case: Corsair 750D ATX Full Tower Case  ($159.99 @ B&H)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($94.99 @ Newegg)
Total: $1820.38
Generated by PCPartPicker 2016-08-09 17:49 EDT-0400
AXIOM
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8260420
(Don't know how to get rid of the quote, just ignore it)
So two questions.
Why did you choose 5820K over 6700K?
And as well, I would love to have a PCI-E SSD for the fastest boot possible due to me being impatient, so why one connected through SATA?
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8260466
If you OC to 7GHz you still won't need that PSU :D
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8263332
So two questions.
The Intel 750 won't boot up windows any quicker, in fact it will probably be slower (Something to do with the pci-e initialization time). A regular 850 EVO would be more than fine.
Is this mainly going to be a gaming pc ?
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8263651
OK, so I will stick with something 650W-ish. Could you suggest some PSU suitable enough for me, please?
I've heard and read many thing that PCI SSD should be faster than a one connected via SATA. Not sure about that, though. And it will be mainly gaming PC, however I will also use Photoshop and Premiere Pro on this machine.
I'm open to your ideas. :)
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8264163
If you are doing other things besides gaming, then look at the Samsung 950 PRO as an alternative to the Intel 750.
https://pcpartpicker.com/product/3F8H99/samsung-internal-hard-drive-mzv5p512bw
Power supply wise a good 550W is enough if you only plan on running a single graphics card. For SLI a 750W would be fine.
These are all good units:
EVGA G2
EVGA GS
Corsair RMx
Corsair RMi
XFX XTR
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8264311
So RM650i I'd say.
And one more thing, how do you connect that Samsung 950 in the motherboard? Apparently it looks different from the Intel 750, so do you need some kind of adapter thing?
Thanks in advance!
EDIT: High wattage explained just now
Thanks so much!
Edited by 4kliksphilip
https://linustechtips.com/topic/640777-will-everything-work/#findComment-8264474
