Right, so I recently installed optifine on my PC to help boost minecraft performance. it was fairly simple. I downloaded the .JAR, clicked open, and selected install. However, when I try to do this on my laptop from the exact same download link it will not run and yes, my laptop has Java. I even tried reinstalling it. Here are some key differences I noticed.
1. On my pc the downloaded file had a java style thumbnail, while the thumbnail on the laptop was just a piece of paper with the corner bent.
2. When I hit open on my pc it showed the install menu for optifine, while on my laptop it just flashed the command prompt for a split second.
I feel like the solution will be stupidly simple, but I cannot seem to figure it out. Any ideas?
https://linustechtips.com/topic/640751-jar-files-and-issues-with-minecraft-mods/
right click > open with > browse > go to your java executable, normally within Program Files if 64 bit, or (x86) if 32 bit
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
The fact that it was a black icon means windows did not know what a .JAR file was on your laptop.
1. Check java is installed, both 64 and 32 bit and check it in internet explorer.
2. go into default programs and associate the .JAR type with java.
3. if nessesary install extra java stuff like JRE
It worked! I told you it would be something stupidly simple.
1. open command prompt
2. type in path to java.exe
3. type in " -Xmx1g -jar "
4. type in path to your *.jar file
end result should look something like this:
C:\jdk\jre\bin\java.exe -Xmx1g -jar F:\HWBot\hwbotprime-0.8.3.jar
http://i.imgur.com/Ns2K7hL.png
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
