21 minutes ago, Lolik said:
Recently I bought new graphic card Gainward 1060, because of high FPS in Games. But the FPS were low (30-60), even when I played with lowest settings.
Please help!!!
Which games? Games like Arma 3 needs a strong cpu and not a strong GPU.
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
https://linustechtips.com/topic/640574-low-fps/#findComment-8258242
2 minutes ago, Lolik said:
Yeah I installed the Drivers. And I compared it and I found out, that the graphic card's memory base clock is locked at 2002MHz out of 4004 MHz, but I don't know how to change it.
World of tanks,CS:GO, Just Cause 3
GPU-Z doesn't pay attention to double bandwith (DDR 3 1600 only clocks at 800 etc.) your memory is fine.
Fire up some game, then look at the utilisation. (should be 99%)
https://linustechtips.com/topic/640574-low-fps/#findComment-8258275
What CPU do you have?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/640574-low-fps/#findComment-8258286
10 minutes ago, Lolik said:
i5-6500
whats the gpu usage?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/640574-low-fps/#findComment-8258331
22 minutes ago, Poohl said:
forgot quote.
wtf? it should be at 99%
Old Rig
https://linustechtips.com/topic/640574-low-fps/#findComment-8258517
What is "low FPS"?
If by meaning your not going over a certain level, make sure you dont have vsync enabled.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/640574-low-fps/#findComment-8259293
Please, expand farther on the issue, could you use a program such as msi afterburner to see what the bottleneck might be? also, what do you call low fps? how much do you get?
Case: NZXT phantom CPU:I5-4460 GPU:MSI-GTX1070 Gaming X RAM:2x4Gb-DDR3-HyperX fury MOBO:Asus Z97-P HDD:Toshiba 1Tb 7200rpm PSU:Sentey650W
https://linustechtips.com/topic/640574-low-fps/#findComment-8259347
