Hey, this is my first post over here on LTT, im planning on building a PC with a budget of about $1000. My plan is to use it for gaming, and building design (AutoDesk building suite). I have a specific goal of getting Minecraft shaders to run at around 60+ fps with around 50 mods (FML).
So I have a few questions...
1. Intel or AMD. I know that amd is way cheaper, but their older processes and under powered single cored performances poses as a real worry for me.
2. AMD (formerly ATI) or nVidia? I would like to go with nVidia, because I've found a lot of cool cards with nVidia chip sets, and I'm more familiar with nVidias side. Is there any real performance gain with AMD or price to performance gain?
3. should I get slightly cheaper GPUs and get 2 in SLI or Cross fire?
Thanks for any answers, also, I'd love to see some of your PC build spec recommendations within my $1000 dollar budget, thanks!
https://linustechtips.com/topic/640366-help-on-pc-hardware-specs/
If all you're going to play is minecraft, which is a mostly CPU bound game, then you can skimp on the graphics card a bit. You're budget will likely end up being more closer to like $600-$700 if all you're going to play is minecraft. I can come up with a build in a bit.
Diamond 5 in League :)
Quote
Intel. There's almost no point in getting AMD right now since their too far behind in performance. If you really want to, you could wait for Zen, but I believe that's slated for next year.
Quote
AMD tends to have a better price/performance ratio but that comes at a cost, at least with the older cards, in increased heat and power consumption. AMD also has no "high end" cards at the moment for this generation, but Vega is supposed to come out by the end of the year or so (I think, I stopped keeping track). The point of contention that both camps will argue for days is about DX12/Vulkan support. It's too early to tell if any of that matters in the future, and it's best to get something that performs well at the present.
Quote
It depends. If you're looking at say a GTX 1070 or GTX 1080 in SLI, it might be worthwhile if you have a 1440p 144Hz monitor to drive. Otherwise it's not worth while. And two lower end cards, like an RX 480 in Crossfire, is not worth it.
Well, as of right now, (running an N celeron with IG) thats pretty much all I can play, I'd like to do some first person shooters too, like call of duty, battle field. that sort of thing. Thanks for the reply!
good stuff, thanks for the reply, ill keep this in mind!
Try building one on PCPartPicker, then we can evaluate your build
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
1. Intel. AMD's current processors are becoming bottlenecks. Once they release Zen, that shouldn't be a problem.
2. That's just starting a flame war. I'd recommend you'd look at some benchmarks of some AMD Polaris cards and Nvidia Pascal/Maxwell cards for yourself.
3. Some games don't have proper SLI/Crossfire scaling or don't have SLI/Crossfire at all (like Minecraft). I wouldn't recommend it for that reason, but if you're playing DX12 games it could be a different story.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
PC Build Guide – AMD FX-6300 ATX: (Less than 700$)
*CPU: AMD FX-6300 + Cooler Master Hyper 212 Evo
*GPU: Gigabyte Radeon RX 480 8GB (can be replaced by RX 470, GTX 970 or R9 390)
*Mobo: MSI 970 Gaming ATX AM3+ Motherboard
*RAM: G.Skill Trident X Series 16GB (2x8GB) DDR3-2133MHz
*PSU: XFX TS 650W
*Storage: Seagate 2TB 3.5" 7200RPM SSHD
*http://pcpartpicker.com/list/KbpgtJ
PC Build Guide – Intel i3 ATX: (Less than 700$)
*CPU: Intel Core i3-6100 (does not need after market cooler)
*Mobo: ASUS H170-PLUS D3 ATX LGA1151 Motherboard
*RAM: Hyper X Fury 16GB (2x8GB) DDR3L-1866MHz (most be 1.35v or less)
*PSU: XFX TS 650W
*http://pcpartpicker.com/list/3vhDxY
PC Build Guide – AMD FX-8370 ATX: (Less than 800$)
*CPU: AMD FX-8370 + Wraith Cooler (does not need after market cooler)
*GPU: Gigabyte Radeon RX 480 8GB (can be replaced by R9 390, GTX 1060 or R9 Fury)
*PSU: XFX TS 650W
*http://pcpartpicker.com/list/vMDCLD
PC Build Guide – Intel i5 ATX: (Less than 900$)
*CPU: Intel Core i5-6600K + Cooler Master Hyper 212 Evo
*GPU: Gigabyte Radeon RX 480 8GB (can be replaced by GTX 1060, R9 Fury or GTX 1070)
*Mobo: ASUS Z170-PLUS D3 ATX LGA1151 Motherboard
*PSU: XFX TS 650W
*http://pcpartpicker.com/list/9zsb8K
PC Build Guide – Intel i7 ATX: (Less than 1000$)
*CPU: Intel Core i7-6700K + Cooler Master Hyper 212 Evo
*PSU: XFX TS 650W
*http://pcpartpicker.com/list/HzZxcc
Complete Example Build: (your build should look like this when done the green is required)
*Case: Cooler Master HAF XB EVO ATX
*CPU: AMD Phenom II X6 1100T + Cooler Master Hyper 212 Evo
*GPU: Sapphire Radeon R9 290 4GB Vapor-X
*Mobo: MSI 970 Gaming AM3+
*RAM: G.Skill Ares Series 16GB (4x4GB) DDR3-1866MHz
*Operating System: SteamOS or Windows 10
*PSU: EVGA SuperNOVA G2 550W
*Storage: Seagate 1TB 3.5" 7200RPM SSHD
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
1. definitely intel
2. kinda depends on the balancing act of your budget, you're probably best off getting a 1060 toward the msrp
3. If you have the choice always get the better single gpu as sli/crossfire support has to be coded for, I believe this holds true with dx12 as well
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Just now, Cyracus said:
1. definitely intel
Saying Intel does not really help, a FX-8300 is better than going for a i3, but if it is a i5 or better Intel all the way! :D
