High temps with watercooling?
Solved by Vasllo,
If it's not reaching the high 80s or 90C, you're probably fine. Games often don't use much CPU, so when you go from 50% usage to constant 100%, your temps go way higher.
BoBo6107 ·
R_public ·
Posted in Networking10 -
apoyusiken ·
Posted in PC Gaming0 -
4
MattJames595 ·
Posted in Troubleshooting0 -
Jimkirk363 ·
Posted in Windows4 -
Ramrod126 ·
Posted in Cases and Mods0 -
smush ·
Posted in CPUs, Motherboards, and Memory7 -
asdasdasdasdasdasd ·
Posted in Hot Deals1
