I need a good CPU cooler to overclock my i5 6600k i will push the bastard to its absolute limit, But i will need a good one because where i live is very very hot i mean i'm on fire right now yeah so my last CPU got fucked up burned to death i don't want the same thing for this one!
https://linustechtips.com/topic/638945-a-good-cpu-cooler/
H100i GTX v2.0 2x120mm AiO liquid cooler - costs around $100.
Nothing to see here ;)
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8241040
air or liquid cooled?
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8241041
Noctua NH-D15 - one of the beefiest air coolers on the market! costs around $75-85
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8241042
Nzxt kraken x61 for $120 or phanteks tc12dx for $50
if (you want to reply) {
 USE THE QUOTE BUTTON
else {
 DONT
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8241045
Go with the h100i gtx from corsair
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8241073
The H100i is not good. Get a EKWB Predator. Much better performance and much MUCH quieter...
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8241107
7 minutes ago, Archfiend said:
I will avoid Liquid cooling, Any other good air cooler other than Noctua NH-D15 ?
That will probably be your best bet. However, if it is really that hot, Air cooling is likely not going to be very effective and give you a big OC until you can bring your ambient temps down.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8241134
If air cooling definetly go with the Noctua NH-U12s or the NH-U14S.
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8241137
If you know your ambient is very hot, adjust your overclock downward. Even the best custom loops can't perform miracles. Unless you enjoy replacing dead CPUs every year, keep your synthetic stress test peak temperatures below 85C regardless of cooling.
That very important disclaimer aside, the best air cooler is the NH-D15, and the best AIO is the NZXT Kraken X61. My opinions, of course.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8242464
Didn't you *just* post this exact same thing somewhere else. Please keep it to one thread to avoid confusion.
My advice remains the same. The X61 or D15 are your best options, and rather than pushing it to the ragged limit, stop when your CPU hits 85C in synthetics.
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8242703
10 hours ago, Archfiend said:
Noctua NH-U12s, - NH-U14S or NH-D15 NH D14 Out of these 4 coolers they kinda look similar which one do you think is the best for me? i did check them out they all have good reviews
The NH-U12 has only one heatsink fin tower and fan. The NH-D14 and NH-D15 both have dual heatsink fin towers and fans. The NH-D15 is a newer version of the NH-D14, and has wider-spread heat-distribution pipes.
You own the software that you purchase - Understanding software licenses and EULAs
"We’ll know our disinformation program is complete when everything the american public believes is false" - William Casey, CIA Director 1981-1987
https://linustechtips.com/topic/638945-a-good-cpu-cooler/#findComment-8244005
