1 minute ago, Neliss said:
Hello, I'm thinking if this power supply will be enough for i7-6700k and gtx 1070
https://www.amazon.com/gp/aw/d/B00EON40CS/ref=mp_s_a_1_1?ie=UTF8&qid=1470385639&sr=8-1&pi=SY200_QL40&keywords=600w+power+supply ?
500W is enough for almost any single GPU setup.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/638346-will-be-enough/#findComment-8234479
2 minutes ago, Arc_Jester said:
Yes but that series is crap, get the BQ or B2 instead.
BQ is a HEC design, I doubt it's much better.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/638346-will-be-enough/#findComment-8234490
Just now, Arc_Jester said:
I was just about to update my post but usually modular designs are higher quality than non-modular ones.
Key word is usually. The Corsair CX500/600 and CX500/600M say hi.
https://linustechtips.com/topic/638346-will-be-enough/#findComment-8234529
11 minutes ago, Neliss said:
No, the EVGA W1s are rubbish. For a i7 6700K + GTX 1070 build, you ought to spend more on a power supply such as the EVGA SuperNOVA 550 G2 or the Corsair RM550x.
This should be your absolute minimum - https://www.amazon.com/CORSAIR-CX550M-BRONZE-Haswell-Modular/dp/B01B72W0A2
https://linustechtips.com/topic/638346-will-be-enough/#findComment-8234653
https://linustechtips.com/topic/638346-will-be-enough/#findComment-8236142
