So I'm upgrading my friends computer.
Only the CPU, motherboard, psu and case are new.
Same ram,HHD,gpu so all that stuff works 100%
It won't boot. The power LED is on tho
What I tried
Tested bot my ram sticks in watch slot.  Solo and together,
Took out my gpu and tried with integrated graphics.
Changed the spots of my front panel connectors.  I tired it in jfp1 and jfp2 in the right way according to the instructions. And I tired it plugged in other ways.
Made sure all the plugs are in the right way
https://linustechtips.com/topic/638074-help-no-boot/
When you say it won't boot, nothing happens(no fans or hdd spin) or just no display?
Are you sure the memory is compatible?
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/638074-help-no-boot/#findComment-8231794
What I tried
could be a bad mother board try discharging it then re plug it in
https://linustechtips.com/topic/638074-help-no-boot/#findComment-8231796
Just now, LeapFrogMasterRace said:
Does the mobo have the latest bios? All standoffs are installed in the case? PSU on the right switch? Take it out of the case to make sure there aren't any shorts and test the psu
Ugh I have to take the board out. Okay I'll try
https://linustechtips.com/topic/638074-help-no-boot/#findComment-8231811
Is the psu working? short start it
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/638074-help-no-boot/#findComment-8231847
