I play on 4:3 streched res and get like 130-180 fps at 144hz
cpu- amd a8 6600k gpu- sapp r9 380x
I know that CSGO is very CPU heavy and my cpu is older but im not sure if thats the problem
i know that fps may seem good to people who dont actually play csgo but i should be getting alot more especially at 4:3
https://linustechtips.com/topic/635951-low-fps-in-csgo/
This all doesn't seem the end of the world, but is vsync off?
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/635951-low-fps-in-csgo/#findComment-8208171
2 minutes ago, acaidia said:
yea thats what i was thinking. i assume an 8350 would improve my fps by alot
On a 8350 with 780ti. I get around 150-200 on 16 player ffa dust2 server. 4x aa and af high everything except shaders on low. With 4:3 about 250. I rather go to a intel cpu just because single threaded performance is more important
https://linustechtips.com/topic/635951-low-fps-in-csgo/#findComment-8208195
Don't go with a FX 8350 or amd at all (at this time when zen isn't released) go with a i5 4690(k)
https://linustechtips.com/topic/635951-low-fps-in-csgo/#findComment-8208289
I had this problem with my G-Sync monitor. I went into the Nvidia Control Panel and unchecked Enable G-Sync (Disabled it) restarted my PC and never showed up again. haha hope this solved your problem.
Edited by Tekneeq
Ooops didn't see you have a AMD Card sorry :(
https://linustechtips.com/topic/635951-low-fps-in-csgo/#findComment-8208416
