Hey guys,
So here's the deal. I fell into the lead position of the IT people at my student union (Living in the Netherlands. I could explain if you wanted to know). Anywho.... Our network is seriously dilapidated. We have wires going everywhere through a building so old I can't actually get to them because it's literally a monument. as far as I remember it's all connected to our custom linux server through an old (like 1980s OLD) HP 'SmartPatch' If I recall correctly.
Here's where you come in, I need advice. and some serious advice at that. The Smart Patch is dying, the fans in it broke years ago and I am not sure it'll survive the summer. I need to know if any of you know what kind of gear would be best suited for the kind of stuff I am using. If I should keep the cables I have (Some of them go to parts of the building I can't get to anymore), Or if I should just find out what cables I still use and patch those back into a new system all together.
I really don't know what's the best approach. I'd be happy to get more details for you guys if anyone is serious about helping me out.
Thanks guys!
https://linustechtips.com/topic/634984-help-with-a-network-setup-overhaul/
12 minutes ago, BioHazard4524 said:
Hey guys,
Thanks guys!
Need something cheap? Go on ebay and get something like the quanta LB4M, or the Netgear GS748T. Both can usually be had for less than $100 USD. If you want something good and cheap, check out the Ubiquiti EdgeSwitch line. The switches are feature-packed and reliable.
My native language is C++
