Best monitor for my GTX1080?
RRGT19
Hi,
I have a GTX1080, I want a monitor for gaming, daily use and coding, I create software with Visual Studio.
Budget: $500
I only like IPS monitors of 24" or 27" inches.
I was thinking about:
1. LG 29UM58 $240
2. Dell U2717D $440
any other?, help me with my choice please
1 minute ago, RGT said:
Hi,
Budget: $500
1. LG 29UM58 $240
2. Dell U2717D $440
What games and what sort of 'daily use tasks' do you find yourself performing?
I'm here to help people and have fun. Feel free to chat!
i5 6500
Asus Z170-AR
Saphhire Nitro 380X
 Hyper X Fury Black 16gb (2x8gb) 2133
GTA V, FALLOUT 4, WITCHER 3, newer games...
Visual Studio, Adobe, web browsing, Movies, etc...
All I can really say is that I have the ultrawide and I love it.
I use the MX 279 H from asus and i love it, ips, 27in, 60hz, for $300, also it looks great, its a very popular monitor, all my friends have it
I would probably get something that's high refresh if possible. I mean it's a 1080 and you'll be hammering out frames like a madman.
Like which one?
What model do you have and why you love it?
I'd say try get a 27 inch monitor then if you aren't doing any super competitive gaming and doing more graphically pleasing and watching movies try and try go for either a 1440p 144htz or 4K monitor to really take advantage of all that horsepower at you fingertips. If you can fit that into your budget go for it. Don't know any specific models...
i5 6500
Asus Z170-AR
Saphhire Nitro 380X
I recommend the Dell S2716DG
Note, it is NOT IPS, but it may as well be... I used to use cheap TN monitors until I bought one of the Korean 27 IPS's three ish years ago and was amazed by it, ever since I've primarily bought Dell Ultrasharps, and I became one of those snobs who says TN is garbage. Well, I got the S2716DG a few months ago and I have to eat my words, its now my primary monitor...
I does have color shift, but I don't fling my head side to side when web browsing, so I never notice it. And there is a slight pink tint that I can't seem to get rid of, but other than that I really can't find any complaints. Honestly the only time I notice the pink tint is when I move a window over to one of the side IPS monitors, and its splitting the bezel, and I promptly forget about it.  Amazon reviews have a lot of good baselines to go with for a calibration that will suit you.
Its typically $510 at Amazon, but as of this post it is higher because Amazon is out of stock of them. Occasionally it will drop around $460 either on Amazon or Newegg.
Its likely a personal preference, but I absolutely hated the 29UM58. I gave it a good try for about a week, and had to return it as it just felt weird to use, I really don't know how to explain it other than it seemed too short even though it really is about the same height as a 21" 16:9 (IIRC).
