hi there all
I am looking at some 18650 batteries and ive come across two that both seem great but not sure which is best.
the samsung 18650 batteries 2500mah https://www.amazon.co.uk/gp/product/B00KYRH1JM/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
or
the panasonic 18650 batteries which are 3400mah https://www.amazon.co.uk/gp/product/B00AIOH9VG/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=A1MH4ZV0T82FAL
help much appreciated
- SSUPD Meshlicous - Z170I - i7-6700K - Gigabyte 2080 - 16GB Corsair Vengance - 850 EVO 1TB - H115i ICUE Link- SF600
https://linustechtips.com/topic/634273-help-with-18650-batteries/
3 minutes ago, Bradders said:
hi there all
or
the panasonic have more mah but the ratings are fake anyways
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
The Panasonic ones have capacity between 3000 and 3400 mAh depending on how much constant power is pulled from there, see this test / review : http://lygte-info.dk/review/batteries2012/Panasonic NCR18650B 3400mAh (Green) UK.html
The Samsung ones have capacity between 2400 and 2500 mAh and they're also good. see test/review here: http://lygte-info.dk/review/batteries2012/Samsung INR18650-25R 2500mAh (Green) UK.html
Apparently both are good. The Panasonic ones would give you more bang for the buck.
I,m  a huge battery nerd and build ridiculous custom flashlights.  Both those batteries are very good but have different purposes.  The panny ncr is a high capacity battery (its dsigned to power something for a long time) the inr trades storage capacity for being able to provide higher current amounts.  The panny version of inrs are pd series.  So really which is the best battery really depends what you want to use it for
planning to use it with a kangertech topbox mini.
Not really familiar with that exact product but a quick google search shows me its either a 50w or 75w vaporizer.  You definatly will want to go with INR type 18650s.  The NCR are going to limit you to about 25-30W.  The samsungs should allow you to pull ~80W although wont last as long.
Thank god i went with the samsungs in the end, almost chose the other ones but then decided against it. not going to use 75w/50w constantly
