Download speed is limited?
The " my network is at 100% usage (100Mbps) " tells me the network card in your computer is configured for some reason for 100 mbps.
Either your network card is capable of only 100mbps , or the other end of the cable is plugged into a 100 mbps port, or the cable had some fault that forced the network card to reconfigure itself in "maximum 100 mbps" mode.
You mention an Asus GigaX 1016D switch. According to its specifications it has 16 x 100 mbps ports, so if you connected your computer to it then your speed will be limited by the maximum 100 mbps speed of the switch.
If this is the case, you need to change the switch to one with gigabit ports, or plug your computer directly in the back of that TP-Link AC1200 router, which has 4 gigabit ports in the back.
