How long can I extend my HDMI cable with extension Adaptors?
The problem with extension via adapters is it relies on the outgoing signal strength (believe it or not some devices are weaker than others) and the quality of the cabling. I have a good 50 foot cable that goes through a brush plate in my office to the other side of my living room to my tv. I used to have an additional 10FT on top of that with no problem, and I tested an extra 25. Though, I would not go over 75 foot myself. If HDMI over Ethernet is not appealing, here's an idea- get good 50 foot cables (they're not bad priced, look for amazon reviews ) and put splitters in between the 50 foot sections of cable as range boosters- there cheap and do the same thing.
Here's a good splitter I use https://www.amazon.com/gp/product/B008D66RAU/ (bonus- it strips HDCP)
Youll notice that hdmi cables you see that are 75 foot and above with good reviews have a "signal booster" in the middle, which is basically a repeater that works about the same way as the splitter but unpowered (using splitters is better for this reason, most hdmi repeaters are unpowered, and are often rated only for ~ 100ft). The latency is negligible, and thankfully for security cameras that doesn't matter very much. If this were a computer you were hooking up, you'd have to worry about USB or a solution for it, my 50ft cable has 2 range extenders in it (same chips as usb hubs) and a powered usb hub on the end to give full device power.
EDIT- changed link to right product
