3-fan setup: all the same fan?
Go to solution Solved by Electronics Wizardy,
Its going to be fine.
For the build linked below, I plan to have the 2 140mm fans that come with the case as front intakes and the separate Noctua one as rear exhaust. All 3 fans have about the same airflow and rpm. Will that be a problem, or does the single exhaust need to be more powerful than the 2 intakes? Does the fan on the D15S cooler count as an exhaust? (It will be right in line with the rear exhaust at the top of the back panel.)
EDIT: I will never be overclocking.
Edited by goof doofus
No overclocking
https://linustechtips.com/topic/632906-3-fan-setup-all-the-same-fan/
Btw you don't need the wireless adapter. The Asus board comes with wifi.
