Which GTX 1080 Is The Best For Less than $700?
TC21
My ASUS 970 never gave me any trouble in the past, but I am wondering if I should consider any of the other brands like MSi or EVGA before purchasing the STRIX 1080. Also is the EVGA SC 1080 at a disadvantage because it only uses 1 8 pin connector instead of an 8+6 pin design?
JayzTwoCents did a review of an MSI card with an extra connector.
The Gigabyte 1080 with one 8-pin does just as well.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Asus, Gigabyte and Zotac have the best value 1080s I don't particularly like EVGAs lineup, they run hot and you don't get a custom PCB until you shell out for the FTW. I would probably just go Asus again if I were you but all I hear about is how bad their RMA is, more power connectors don't matter and I would rather have more power phases.
I've heard that EVGA has some of the best customer support in the market - if I decide to get a 1080 I'm probably going to go with them.
It seems that most aftermarket 1080s perform about the same with manual overclocking.
CPU: i7-4790K --- HEATSINK: NZXT Kraken X61 --- MOBO: Asus Z97-A --- GPU: GTX 970 Strix --- RAM: 16GB ADATA XPG --- SSD: 512GB MX100 | 256GB BX200 HDD: 1TB WD Black --- PSU: EVGA SuperNova G2 --- CASE: NZXT H440 --- DISPLAY3 x Dell U2414H --- KEYBOARD: Pok3r (Clears) --- MOUSE: Logitech G Pro --- OS: Windows 10
The extra 6/8 pins allow for better power delivery for overclocking. If you're an avid overclocker, consider getting the EVGA FTW Gaming. Otherwise, most other models will do fine, it's more of a question of aesthetics and customer support at this point.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
The Gigabyte 1080 with an 8-pin matches the MSI with 6+8 pin. It's more up to power phases/delivery than it is pins. But yes, some cards with more pins do get better overclocks due to higher headroom.
I've heard a lot about how bad their customer support is. Thankfully I haven't had to use it but I hope I don't have to with this card.
Are there any benefits to the ACX cooler vs. the triple fan design on the STRIX?
The FTW is $749 so it is out of my price range. I haven't heard much about the MSi version so I guess I might go for the STRIX.
I am planning to do some overclocking so I guess I will go for a card with the 6+8pin.
Look for more power phases not pins. Refer to my two videos.
Huh, strange seeing how the STRIX is much more expensive than the FTW in the US. The ASUS STRIX will come clocked higher out of the box but the MSI has slightly better cooling and will likely achieve similar clocks once overclocked. Like I said, just a question of customer support quality and aesthetics.
