6 minutes ago, DAnewguy said:
Do I need a pump for just  water cooling Cpu??
Cooler example
Corsair Hydro H100i v2
Sry for my stupidity
A pump is always required for current liquid cooling. The cooler comes with a pump as it is an All-in-one style.
https://linustechtips.com/topic/631764-do-i-need-a-pump/#findComment-8157209
Just now, DAnewguy said:
Sorry for meybe a very dumb question but what about the liquid it self is it in all ready?
Yes. The liquid is already in the cooler and no maintenance is required except for the occasional cleaning of the radiator.
https://linustechtips.com/topic/631764-do-i-need-a-pump/#findComment-8157216
Well I should ask in a better way if it has a pump or not
It has a pump integrated into the block that mounts against the CPU.
https://linustechtips.com/topic/631764-do-i-need-a-pump/#findComment-8157225
Yah, it has a pump and liquid all contained and ready to go. No assembly is required on your part in terms of the cooler.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/631764-do-i-need-a-pump/#findComment-8157226
H100i is simple.
Buy it, mount it and turn on PC.
Simple as that. Nothing else needed.
It's AIO cooler. That mean rad + pump + liquid + fan is all alredy put together. It's kinda plug and play xD
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/631764-do-i-need-a-pump/#findComment-8161409
