So I recently got a new computer, no more than a few weeks old and for awhile I've noticed some clicking noise. Some would probably say to check the hard drive, but I don't think that the hard drive is the problem. The clicking noise happens once, every now and then, never repeating. Not only that, this happens when the pc is both off and on. So should i be concerned about this and what part is causing this?
https://linustechtips.com/topic/631757-odd-clicking-noise/
1 minute ago, YoFavRussian said:
I was going to suggest something in a fan until I saw that you said it does it when it's on and off.
maybe the fans were still spinning from the momentum right after turning off, thats what I am thinking rn
https://linustechtips.com/topic/631757-odd-clicking-noise/#findComment-8157113
Clicking? While ON and OFF? Could be a cockroach! Those little buggers have massive jaws!
I would check all the connections first. PSU, GPU, etc. Even when your computer is off it still draws some power and you may be hearing arc'ing.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/631757-odd-clicking-noise/#findComment-8157151
4 hours ago, YoFavRussian said:
With a car, mower, ETC. it's understandable, but a PC, never heard of that.
My case doesn't do it, but my monitors totally do that 'cracking' sound when they first power up or power down as the plastic in the monitors warms or cools and slightly changes shape.  I mean, it's not SUPER apparent and the TV easily drowns it out if you aren't listening, but totally happens.  This is why I asked the OP to unplug it, if it happens while it's unplugged, it rules out everything electrical/mechanical in the computer and it's likely due to temperature change.
https://linustechtips.com/topic/631757-odd-clicking-noise/#findComment-8158567
It would be nice if the author of the post actually let us know if they have tried anything that has been suggested.
https://linustechtips.com/topic/631757-odd-clicking-noise/#findComment-8168694
OP probably forgot he has this thread, hasn't had the issue, or doesn't care.
https://linustechtips.com/topic/631757-odd-clicking-noise/#findComment-8169294
