I'd borrow a friend's computer and follow Linus's instructions here:
Or go pry your friend's optical drive out of his PC and promise to return it.
Or just pick one up from somewhere for $15.
34 38 20 36 35 20 37 39 20 32 63 20 32 30 20 37 33 20 37 34 20 36 66 20 37 30 20 32 30 20 37 34 20 37 32 20 36 31 20 36 65 20 37 33 20 36 63 20 36 31 20 37 34 20 36 39 20 36 65 20 36 37 20 32 30 20 37 34 20 36 38 20 36 39 20 37 33 20 32 65
https://linustechtips.com/topic/6308-help/#findComment-69337
I say borrow one if you don't want to spend the money,
Just I don't advise going to the length I went to with my server.. which was old IDE DVD drive hooked up to an external IDE->USB dock into the IO on the Motherboard.. it wasn't pretty
Arch Linux on Samsung 840 EVO 120GB: Startup finished in 1.334s (kernel) + 224ms (userspace) = 1.559s | U mad windoze..?
https://linustechtips.com/topic/6308-help/#findComment-69355
As others have mentioned, the easiest and quickest thing to do is to just find an optical drive to use for a while, either to install it from that drive or to use somebody else's computer to make a USB drive out of the DVD.
CPU: Ryzen 7 3700X, RAM: 16GB (2x8GB) XPG GAMMIX D30 DDR4 3600MHz, MOBO: ASRock X570M, GPU: GIGABYTE RTX 2070 SUPER (Corsair H100x cooling), SSD 1: Corsair Force MP510 240GB, SSD 2: Patriot VPN100 1TB, OS: Windows 10 Professional x64, CASE: Open air test bench
https://linustechtips.com/topic/6308-help/#findComment-69474
OMG that video from Linus is soooooo complicated for nothing.
I guess he never heard that Microsoft made a tool to do just that: http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
1- You make an ISO out the disk.
2- You run the program from Microsoft, select the ISO, and it will prepare the USB flash drive, extract the OS ISO disk image, and make the drive bootable, all for you. That is it!
3- Plug the USB drive to your computer, boot from it, and install Windows 7 (or 8) in a few minutes.
Note: You need a computer running a 64-bit Windows to do the above.
https://linustechtips.com/topic/6308-help/#findComment-69494
Use Win2Flash to do it. Very similar to what "GoodBytes" said, except you don't need a 64-bit OS and it's not an official tool. I've done it lots of times :)
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/6308-help/#findComment-69526
