So I have a 600b evga power supply i5 6600k cpu 8x1gb of hyperx ram asrock z170 pro4s and a cpu cooler so the problem is I got it to post once and everything looked good and I turned it off to move it to a place down the street so I could download everything and now all it will say on the screen is reboot and select proper boot device or insert boot media in selected boot device?
https://linustechtips.com/topic/630473-my-build-wouldnt-post-now/
Just now, Hejo66 said:
So I have a asrock z170 pro4s, i5 6600k, hyperx ram, evga 600b bronze pcu, and a cooler master cpu cooler so the problem is I got the pc to post once and I turned it off moved it and now wouldn't post
And it's saying reboot and select proper boot device or insert boot media in selected boot device and press a key
how are you getting text to display if it wont post? do you have a hdd /ssd or bootable flash drive connected ?
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
insert a windows install disk/usb to make ine download the windows media creation tool from microsofts website
****SORRY FOR MY ENGLISH IT'S REALLY TERRIBLE*****
Been married to my wife for 3 years now! Yay!
I have a ocz ssd 240gb connected
im assuming its empty, so youll need to make a bootable usb drive and install an os
