I am hopefully going to be upgrading to an i5 6600k and I want to get an air cooler for it for now and I just wanted to ask the forums for some recommendations. I don't want to spend really more that $50 on an air cooler because at that point I would just buy like a corsair h50. An as for a reference I do like cooler with this kind of shape, but I would like to get one with either a blue or black fan instead of the white one. Thanks in advance!
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/630403-i-need-a-cooler-recommendation/
look at the cryorig h7
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
Those coolers that sit like that are made for ITX builds with space constraints. They will not perform as well as a tower cooler of a similar price point.
Why would you want to get an H50 if you spend over $50? An H50 is a very budget AIO and I don't recommend buying one since a good air cooler will be just as good if not better, and will be much more quiet.
Just get a Cryorig H5 and be done with it.
