travel storage's device
Go to solution Solved by Mighty_Miro_WD,
18 hours ago, zehao39 said:
thanks for replying. However,I am just look for something simple.a stable hhd when I travel is all I need. Do you have any suggestion
You're welcome! :)
For a portable external drive you can take a look at WD My Passport Ultra, which was suggested by @Crunken, or WD Elements. They both are very good and reliable drives, and the only difference between them is that the first one is hardware encrypted and password protected while the first one is not. As for the maximum capacity, WD Elements comes with maximum available storage space of 2TB while WD My Passport is up to 4TB.
Here's a link you if want to take a look:
WD Elements - http://products.wdc.com/support/kb.ashx?id=vtkvmq
WD My Passport Ultra - http://products.wdc.com/support/kb.ashx?id=J6nXMK
Cheers! :)
hi
As a hobby I took a lot photo when I travel. However,the raw format of photo are take a lot of space In my laptop. The 256gb ssd in my laptop is not enough. I need some portable devices I can use to keep all My photos. Is there any products out there are cheap and stable for travel that I can hold tons of the photo. The most important thing will be stable. I really do not need the speed. Do you guys have any suggestion?
https://linustechtips.com/topic/628367-travel-storages-device/
Hi there.
If you want you can take a look at WD Wireless Pro. The drive is a mixture of a portable HDD, a NAS, a router and a SD card reader.
It has a SD card reader from which you can upload pics directly on the drive with button that automatically copies/cuts the content of the SD card onto the drive itself with one press. Also, it has an USB 3.0 port that will allow you to transfer large .RAW images and an additional USB2.0 port which allows you to either charge another device or connect an additional drive to it.
Here's a link if you want to check it out:
http://products.wdc.com/support/kb.ashx?id=rik5Eb
Hope this helps and feel free to ask any questions you may have. :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
https://linustechtips.com/topic/628367-travel-storages-device/#findComment-8109116
47 minutes ago, Mighty_Miro_WD said:
Hi there.
https://linustechtips.com/topic/628367-travel-storages-device/#findComment-8109965
https://www.amazon.com/Black-Passport-Ultra-Portable-External/dp/B00W8XXYSM
This is pretty cheap at the moment, big capacity aswell and small enough to travel with :)
EDIT: Also i've never had any problems with stability on any WD harddrive
https://linustechtips.com/topic/628367-travel-storages-device/#findComment-8110857
You're welcome! :)
Cheers! :)
https://linustechtips.com/topic/628367-travel-storages-device/#findComment-8121571
