Do aftermarket CPU fans transfer?
layarion
If i buy a fan cooler, and then 3 years from now get a new cpu from the same brand. are chances good that i can still use the same cooler?
Depends on what CPU you get, and what kind of activity you did on it
DESKTOP PC :
  CPU :RYZEN 5 2600/ GPU :MSI Ventus OC GTX 1660 Ti/ RAM :Team Elite 2x8/ PSU :Corsair CX650M/ HDD :Toshiba 2TB/ SSD :Adata XPG M.2 SATA 265GB/ COOLER :Be Quite 2x140mm / MOBO :Asus TUF B450 Gaming
LAPTOP :
  CPU :i7-4710HQ/ GPU :GTX 860M/ RAM :8GB OEM/ HDD :1 TB
PERIPHERALS :
  MOUSE :LOGITECH G502/ HEADSET :HyperX Cloud Alpha/ KEYBOARD :Logitech G Pro
POSSIBLE PC BUILD :
  PC PART LINK
A lot of the current coolers are usable with LGA sockets (all of them), so I don't see why it would change since the companies would rather have one cooler working with as many motherboards as possible. But I can't say for certain if that will or will not change.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
If it doesn't have native socket support, most popular coolers will have brackets for new sockets.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
