I need some help with my first ever canadian pc build.
As you know I live in canada and I am willing to spend $500 - $650 on this build.
This build is for gaming and video editing/rendering. As far as games go, I mostly play all game genres (that includes indie titles). I prefer having better performance than graphics.
I dont think Im going to do any crossfire/sli since this is my first build
I am planning on running only one monitor. For peripherals, I need a cheap keyboard, a monitor, and an OS. I am not sure if I am willing to spend a $100 on windows 7/8 or just get Linux... so either one is fine.
Im planning on buying all the aprts at around christmas (since my birthday is on december the 23rd).
I need to upgrade because I have been gaming and editing videos on a hp pavilion g6. It is slow and I just cant play games with friends because I lag....
Thank you for your time!
All comments are appreciated :D
https://linustechtips.com/topic/62744-first-build-help-canadian/
inb4CoolBeans
And I just reread that. If you need a monitor and peripherals, I wouldn't want to be editing videos on that. Makes your budget closer to $450.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-857065
at that budget i would highly recommend a AMD APU based System. this way you are getting the best CPU AND GPU performance possible and later down the road you can add a dedicated GPU as well.
PCPartPicker part list: http://ca.pcpartpicker.com/p/1LbGW
CPU: AMD A10-6800K 4.1GHz Quad-Core Processor  ($151.98 @ Newegg Canada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ NCIX)
Motherboard: Asus A85XM-A Micro ATX FM2 Motherboard  ($66.50 @ Vuugo)
Memory: Patriot Viper 3 8GB (2 x 4GB) DDR3-1866 Memory  ($64.30 @ Amazon Canada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($89.79 @ DirectCanada)
Case: Corsair 350D MicroATX Mid Tower Case  ($86.19 @ DirectCanada)
Power Supply: Corsair CX 430W 80 PLUS Bronze Certified ATX12V Power Supply  ($49.99 @ Newegg Canada)
Total: $538.74
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-10-05 15:08 EDT-0400)
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-857190
I couldn't agree more with the A10 6800K (as long as your monitor's resolution is smaller than 1920x1080) , but for the case, the N200 by Cooler Master would be just fine and it costs half that much.
Also, if 2TB is way more then what you need, select the WD10EZRX by Western Digital. It's cooler and quieter than normal HDDs.
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-860397
CPU:  AMD FX-6300 3.5GHz 6-Core Processor  ($109.99 @ Amazon)
Motherboard:  Asus M5A97 LE R2.0 ATX AM3+ Motherboard  ($69.99 @ Newegg)
Memory:  Team Elite 8GB (1 x 8GB) DDR3-1600 Memory  ($58.98 @ Amazon)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.98 @ Outlet PC)
Video Card:  PowerColor Radeon HD 7950 3GB Video Card  ($179.99 @ Newegg)
Power Supply:  OCZ ZT 650W 80 PLUS Bronze Certified ATX12V Power Supply  ($69.99 @ Microcenter)
Optical Drive:  Lite-On iHAS124-04 DVD/CD Writer  ($14.98 @ Outlet PC)
Mouse:  A4Tech D-530-FX1 Wired Optical Mouse  ($13.99 @ Amazon)
Total: $652.69
(Generated by PCPartPicker 2013-10-06 09:34 EDT-0400)
AMD FX 6300 | ASUS M5A97 R2.0 ATX AM3+ | HITACHI ULTRASTAR 1TB 7200RPM HDD | XFX RADEON HD 7950 3GB | 8GB DDR3-1600 MUSHKIN BLACKLINE | OCZ ZT 550W 80+ BRONZE PSU | ZALMAN Z5 PLUS CASE | LITE-ON iHDS118-04 DVD/CD DRIVE | BENQ GW2255 21.5" MONITOR
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-860440
Total: $538.74
Ive heard havin faster ram will help the build...is that true?
Also how do u add a dedicated gpu? do u just stick it in the build?
I also dont think ill be needing 2 tb of harddrive memory...
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-860660
Then take the quoted build with my modifications. Faster memory only means better performance with an APU, wich is the case of the A10 6800K. And the listed 1866 MHz is faster that normal already ;)
Adding a dedicated GPU is very easy (even if you were not the one building the system). You simply stick it in indeed, an add one cable from the power supply.
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-861438
same as this ^^^^
you might not need 2tb but you will be paying more per GB if you go for a lower capacity drive.
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-861592
CPU:  AMD FX-6300 3.5GHz 6-Core Processor  ($114.99 @ Canada Computers)
Motherboard:  Gigabyte GA-970A-D3 ATX AM3+ Motherboard  ($69.99 @ Memory Express)
Memory:  Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory  ($55.99 @ Amazon Canada)
Video Card:  XFX Radeon HD 7950 3GB Video Card  ($229.99 @ NCIX)
Case:  Cooler Master HAF 912 ATX Mid Tower Case  ($44.99 @ NCIX)
Power Supply:  Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply  ($54.99 @ Canada Computers)
Total: $630.93
(Generated by PCPartPicker 2013-10-06 17:11 EDT-0400)
Case: Xigmatek Alfar (Black) | CPU: Intel Core i5 4460 @3.2GHz | MoBo: Gigabyte GA-Z87-D3HP | RAM: Crucial Ballistix Sport 8GB 1600MHz | GFX: Gigabyte GTX 660Ti 2GB
Cooler: beQuiet! Shadow Rock | SSD: Samsung 840 EVO 120GB | HDD: Seagate 'Barracuda' 2TB| OS: Windows 8.1 PRO (64-bit) | PSU: Zalman ZM600-GT 600W 80+ Bronze
 Screen: ASUS VS228 | Mouse: Razer Naga Molten | Headphones: Qpad QH-85 | Keyboard: Razer Blackwidow 2013 w/ Cherry MX Blue
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-862208
Plan later. Parts and prices change frequently and things will be very different by December.
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-862536
Ive been wondering, if i dont have enough do u think its smart to just get linux instead of windows 7/8 ?
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-863343
10 months ago I would have said that Linux is everything but a viable gaming platform, but things are changing very fast. The rate at which game are ported to Linux is nothing short of astonishing (thanks to Valve's efforts). So yes, you can get Linux (my favorite distribution is Lubuntu) and know that you'll have a decent game selection that will keep growing faster as months go by (through Steam). However, I have my doubts regarding triple A titles. It's too soon to tell how much attention this OS will receive from big publisher's most ambitious titles.
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-864454
Basically, wait and see.
It doesn't look like you're in a rush.
https://linustechtips.com/topic/62744-first-build-help-canadian/#findComment-877831
