5 minutes ago, gevy said:
I'm planning to build a wall mounted PC and I often read something like the pcie riser cable can reduce the performance of the graphics. Is it true?
Get the correct type, which is x8 / x16. It better be of good quality too. If these criteria are satisfied, your riser will work just fine :)!
Nothing to see here ;)
1 minute ago, gevy said:
and the x16 will not affect the performance?
x16 cable shouldn't affect performance, just make sure you get a good quality shielded cable. Cheap cables usually aren't shielded properly and will cause problems.
If you need help with your forum account, please use the Forum Support form !
It shouldn't! If it really is x16, it will perform as if the GPU is directly plugged into the motherboard - it's that good!
