I just realized this possibility. I mean, there's got to be something that displays the little monitor menu. Like...it's not the CPU in my PC that does this.
Night Fury 2.0:
Intel Core i5-6500 / Cryorig H7 / Gigabyte GA-H170-D3H / Corsair Vengeance LPX 8GB DDR4 @ 2133MHz / EVGA GTX 1070 SC / Fractal Design Define R5 / Adata SP550 240GB / WD Blue 500GB / WD Blue 1TB / EVGA 750GQ
Daily Drivers:
Google Pixel XL 128GB / Jaybird Bluebuds X3 / Logitech MX Master / Sennheiser HD 598 /
https://linustechtips.com/topic/626498-do-monitors-have-microprocessors-inside-them/
Yeah of course, just like your microwave or washing machine.
Something has to turn a display signal from HDMI or DP into pixels on the screen.
1 minute ago, wrathoftheturkey said:
So yes
Could you run Cinebench on it? LOL
Night Fury 2.0:
Daily Drivers:
Probably not, but I'd like to see someone try it :P
Other systems I've built:
2 minutes ago, Alexzz_ said:
no, it is a processor that is specifically designed for outputting video and displaying the menu. it cant run anything else
It depends on the monitor. I've seen monitors with pretty powerfull ARM based cpu's to run advanced image enhancing DSP routines. Cinebench might be a stretch but those would certainly be able to run a wide spectrum of software. The lack of a OS would probably be the biggest hurdle.
It's not a CPU, it's an asic. It's hardware coded to process a digital signal and produce images. You can't run software on it unless  it is a real all-purpouse CPU like the ones in tvs. Afaik monitors don't have the capabilities that smart tvs do, so no, computer software cannot run on it.
Like i said, seen plenty of monitors with a generic purpose ARM cpu and flash ROM for the software. If you had the knowledge of how the monitor works internally and reprogram the rom you could make it run anything from pong to quake, as long as there is enough RAM and ROM space.
Those were all higher end monitors tough. Cheap monitors will idd include a ASIC or FPGA.
It depends, SOME monitors do actually have full cpus but they are not very many. More notably, many modern monitors have menus and functionalities that are difficult to hardware code, but I'm not sure if they do actually use a cpu or a particularly complex asic.
sudo chmod -R 000 /*
lots of things have microprocessors in, toasters even
