If i have the "front" side panel of my case open do i have to keep my fans on or can i turn the off for quieter operation?
If it helps i have a 140mm top exhaust fan and front 120mm intake fan. Both are vey loud because the are running off molex (at full speed all the time).
FX 6300 | Sapphire 7770 | G-Skill Ares 8GB | WD Blue 1TB | ASUS M5A78L-M
Tritton Kunai | Logitech Proteus Core G502 | Razer Blackwidow Tournament
https://linustechtips.com/topic/62641-open-case-cooling/
You don't really have to have case fans tbh so turning them off won't hurt anything.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/62641-open-case-cooling/#findComment-855665
don't take your side panel off in the first place it will let dust in and will cause your temps to rise when dust is all over your components
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/62641-open-case-cooling/#findComment-855675
If you are going to turn off your fans, just make sure your temps are okay.
You'll get dust if you have more exhaust than intake though.
https://linustechtips.com/topic/62641-open-case-cooling/#findComment-862449
a 7770 and a stock clocked 6300 shouldn't have any problems even while gaming. I've turned off my fans before and my temps were acceptable.
https://linustechtips.com/topic/62641-open-case-cooling/#findComment-863170
