is my isp limiting youtube's connection speed,or is it youtube's fault?
McHox
hey, i have a 50Mbit/s plan and i am mostly getting all of it(sometimes even more,e.g. 7 Mb/s in steam).
for a few day i can't really watch yt videos in 1080p without buffering every 2 seconds and i'm getting about 1230 Kbps(from the video stats) from youtube.
is youtube as slow as this for anyone else? could this be my isp(deutsche telekom) limiting the speed from youtube?
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
2 minutes ago, Lurick said:
Have you tried running this test:
https://www.battleforthenet.com/internethealthtest/
i didn't but the result is 6.93 Mbps,so no problem there
If you get a vpn, isps have a hard time trying to  throttle you as they have no clue telling weather you are watching youtube or not as a vpn sends one line of data to isps.
but the free ones i know usually suck,and i don't want to pay for it
tried tunnelbear yet, works a charm for me ;-)
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
Ugh, www.speedtest.net
3.Use
I think it is YT because it is happening to me too. Currently investigating.
A water-cooled mid-tier gaming PC.
ah, a fellow tunnelbear member
*ignore this one,can't delete*
while watching netflix
tunnelbear is only 500mb? right? thats about an hour of 480p
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
Could be youtube having some technical issues/doing updates. Are you watching old stuff/ does it occur on everything you watch? Nerver heard telekom throttles anything here.
3.Use
yep,the free version at least.i think you get an extra 500 if you tweet about it
I pay yearly and I assume he does to.
extra 1GB
3.Use
old/new stuff,on everything.and the telekom doesn't have the best reputation for this kinda stuff
 load this video directly from youtube at 1080p it should take 4-6 seconds
the video is 49 seconds even though its a 30 second timer
Dendrotoxin
Perripherals
the page itself took about 10 sec,video was buffering ~15 sec. before starting and the video loading took another ~10 sec.
Unfortunately a lot of ISP's tend to throttle Youtube/Streaming traffic, so the likes of Netflix get punished for their bandwidth absorption capabilities, unless you mask the traffic using a VPN it is fairly difficult to stop ;-(
Jr. Systems Administrator
*All my opinions are my own based on my Technical Experiences and Tech Reviews!
netflix is as fast as it should be :( it's only youtube
If you have buffering problems it may be worth checking the CPU usage etc of the browser as this negatively impacts the amount it can buffer, has it done this in the past or is this just suddenly effecting you? :(!
i guess that won't be a problem with my 4790k
i only have this plan for 2 months and it started about 2 weeks ago
  Hide contents
Fair enough! I'd say you're safe on usage terms; has the modem & or router been restarted since? I tend to find, oddly that VM in the UK tends to drop the speed of the connection / throttles it heavier based on how long the device has been on.
I would have presumed you have done this already as soon as you were aware of the issue, I would query Deutsche Telekom as to whether they are having any speed issues with the likes of Youtube as this could be down to peering issues, albeit unlikely!
Are you sure that works?  We get anywhere from 20 to 25 Mbit and that's showing like 8 - 9
