I am fixing a rig for a friend the pc won't run games at a steady frame playing gta well below vram limit stutters from 60fps to 100fps to 1fps idk why then it crashes after a few minutes any ideas
Specs
Gtx 950sc
16gb ddr3
evga 500watt psu
fx6300 stock heatsink
asrock 970mpro3
https://linustechtips.com/topic/625616-help/
If an Intel fanboy doesn't ninja me, they'd probably blame it on it having an FX 6300.
Is there any overclock being applied to the CPU or GPU?
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/625616-help/#findComment-8074075
no oc on either cpu or gpu
https://linustechtips.com/topic/625616-help/#findComment-8074081
Can you open up task manager or MSI Afterburner to see what happens before, during, and after crashes?
Post screenshots (cut the windows out) if you can.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/625616-help/#findComment-8074098
70 to 90% cpu usage 6300 is warm but he only has stock heatsink the 950 temp is 24degrees then back to 10 degrees usage is %54 about right using 1gb of vram ram usage spikes one then to the bottom 1 stick or ram is taking all usage for the game gta freezes when running afterburner at the sametime
https://linustechtips.com/topic/625616-help/#findComment-8074186
I would try a stress test with Prime or Aida to see what temps he gets at full load. If he's hitting 100% with good temps it's probably not thermal throttling, in which case I would see if anyone from the AMD camp knows if it's... Wait, what GTA? If it's V, then you probably have a bottleneck as GTA V has a lot of AI that must be handled by the CPU.
https://linustechtips.com/topic/625616-help/#findComment-8074216
I turned down population density/variety to none no distance scaling either no aa everything is at low
https://linustechtips.com/topic/625616-help/#findComment-8074254
How old is the OS? Is there any chance of backing up the files he needs and clean installing?
https://linustechtips.com/topic/625616-help/#findComment-8074275
win 10
https://linustechtips.com/topic/625616-help/#findComment-8074277
1 minute ago, masterkickass7 said:
win 10
And the game is GTA V? I would definitely seek out someone who has more experience with AMD CPU's since I would say it'd be a bottleneck.
Is there any chance that this is a bottlenecking situation. I don't think it is but I haven't used AMD since the Athlon was unveiled.
https://linustechtips.com/topic/625616-help/#findComment-8074295
yeah i am about to
https://linustechtips.com/topic/625616-help/#findComment-8074306
Yeah idk. Eh I'm mostly on AMD laptops. I'm not really sure about their desktop stuff though.
https://linustechtips.com/topic/625616-help/#findComment-8074334
6300 runs gtav just fine, atleast it does for my brother. It could be thermal throttling tough in either cpu itself or parts in mobo. can you download hwmonitor and msi kombustor. After that use kombustors cpu test and check the temps and clock speeds for the cpu tru hwmonitor and take printscreen after its been running for little while
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/625616-help/#findComment-8074435
12 hours ago, masterkickass7 said:
yeah i am about to
could a hdd have to do was installed on my 750gb laptop hdd pulled it out installed on a 250gb hdd and now gta getting solid 60 all medium settings
https://linustechtips.com/topic/625616-help/#findComment-8076833
