HELP
Go to solution Solved by Squarq,
You can use header tags such as <h1> <h2> h3> etc. . . As you increase the number, the font gets smaller. A <p> tag should work just fine though if you're trying to write a sentence.
Hello I want to know how to make a sentence in HTML. I know there are the <p> and </p> tags for paragraphs but i'm not sure if there is anything just for sentences.
Thanks in advance
Duh_Tech
I am a computer and aviation enthusiast. I have a good enough PC.
https://linustechtips.com/topic/625352-help/
A sentence doesn't have its own semantic markup (so sentences don't need a tag around them), because the full stop (period) is a semantic marker to divide the paragraphs. However, if you want it in a tag to style it or something like that, you should use <span>.
The sentence should go inside another tag though, and for the main content of your page that will usually be <p>. You can inspect element on this post to see what markup was used to make it - you'll find that each paragraph is a <p>, and the text is directly inside that.
HTTP/2 203
https://linustechtips.com/topic/625352-help/#findComment-8071374
