Today i turned on my PC and it was running quite slow. Even though disk usage was extremely low, CPU usage doesn't exceed 10%, Memory usage doesn't exceed 50%, my computer is running extremely hot. I don't hear my fan running. I don't have many programs running, and there aren't any viruses (assuming there are no viruses detected since this update). My CPU is currently running at 93-94ºC as me writing this post, and my GPU at 118ºC-119ºC. That's is extremely abnormal. The CPU temperature is like if it had no thermal paste. I only watched a youtube video and then this started happening. My CPU temperature is going up rapidly. IT'S AT 97C THIS TIME http://speccy.piriform.com/results/s5byIaRt77JOzOphdVG5RG6
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/625108-pc-extremely-hot/
118 °C ? Sounds like a bug to me, did you clean already the PC?
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068240
What cooler do you use on your GPU and CPU? Have you recently worked on your PC? You might have accidentally knocked out a cable or the cooler has come lose. Try reinstalling the CPU cooler. Also what case do you have?
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068247
Open the sides and see if the fans even run, if they dont then check the cables like @Warning kinda suggested.
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068257
There are many possible factors-
  1. physical damage from servicing
  2. dried out CPU thermal paste
  3. damaged CPU fan
  4. damaged GPU fans
  5. old GPU with dried out thermal paste and degraded thermal pads
  6. temperature sensor error
  7. many other minor faults
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068262
CPU with stock cooler, i have a case which i don-t know the name. Things went very unusually slow and the BIOS shows same results. The BIOS shows the fans running at around 1550 RPM. This is prebuilt and it has worked fine before for years.
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068264
mobo is running 49c so ambient in the case isnt that hot really. Can you install hwmonitor and see all the temps from mobo
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068270
Have you reapplied thermal compound recently? and if yes, what did you use? And like the other guys are saying. Check cables. But i highly doubt that the cooler has come loose ad it will be very hard to to by hitting it.
I had a GTX 580 at 68 idle because of bad thermal compound
It could also be a glitch. try removing the side panel and stick your hand inside. Does it feel hot?
Also try checking the temps. in BIOS. It could be a software issue.
Also try manually setting fan speeds with MSI afterbuner and speedfan
CPU: 2x E5620 - GPU: 2x GTX660 - RAM: 64gb DDR3 ECC - Mobo: Z800 OEM - Storage:1TB WD Green - 256gb - Micron C400 250gb - 850 EVO - 512gb 850 PRO
Monitors: 3x HP ZR2440W - Keyboard: G710 MX Blue - Mouse: MX Master
Keep up the good tone and stay classyxD
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068280
Forgot to mention, it turns off very rapidly
Its most likely for overheating
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068283
My SSD runs at 400C on HW monitor :) There are abnormalities with those temps- an Intel CPU at this temperature would shut itself down already.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068291
  3. damaged CPU fan
  4. damaged GPU fans
What i think is 2, 4, 5 or 6 (maybe 7).
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068318
unfortunately for your expectations i turned off my computer when the CPU temperature was 98ºC and my CPU freezes (shuts itself down) at 100ºC
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068322
  3. damaged CPU fan
  4. damaged GPU fans
1, 6 & 7: defenately possible
2 & 5: even no paste at all shouldnt be this dramatic
3 & 4: once again, shouldnt be this dramatic.
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8068381
i left it out for a bit more time (1 hour) and it was much more cool
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8099428
Really strange, both your CPU and GPU are hot. Sounds like a motherboard or power supply issue to me. Try with different board or PSU if you can. You can try changing the paste and touching the radiator. If you can hold your finger on it near the CPU with brand new paste-it's a problem with sensors or mobo. Hope you fix the issue!
https://linustechtips.com/topic/625108-pc-extremely-hot/#findComment-8099518
