just put it in. :)
(maybe on top of your PSU or anywhere where is space)
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-852551
could you post a picture of
1. your case without a panel
2. your case on the backside with panel removed
3. your modem
if you can take all these pictures with a ruler next to the so i can get a reference i'll work something out for you
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-853785
3. your modem
Actually, I plan on doing it in the next build. My case is a HAF 912 and Its too loud and ill likely sell it
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-853966
If it's overheating why not just put on a fan on the modem and leave it oustide of the case. I've seen several people do this with routers which get a little hot. To answer your question however it's entirely possible unless size is a problem, you'll have to run power and such to it though so it's probably going to look bad and clutter your case.
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-854605
Cable management is a hobby of mine
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-854725
if you really want a cool router maybe you could cool it with mineral oil? :D
have extension cables running from it to access everything. it would essentially be a box with oil
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-855194
You have created a monster
oops  :ph34r:
But it would be fairly simple but im not sure if its worth the hassle  :P
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-856898
This is actually a pretty coll idea and k might steal it for my home networking solution :P
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-860968
Just open the case of the modem place the main-board into the pc case instead and build it onto a side panel in a motherboard mounting frashion.will get fairly good cooling,but there needs to be case modding to make the hex nuts (for the screws ) attach to the panel.
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-877829
You should look into building a custom water cooling loop so you can overclock it.  But seriously, what Giggitygoebbels said makes the most sense.
| Currently no gaming rig | Dell XPS 13 (9343) |
| Samsung Galaxy Note5 | Gear VR | Nvidia Shield Tab | Xbox One |
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-878578
But it isn't as fun hehe, and i move my case around too roughly for watercooling
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-879430
I was also thinking about it, somemodems and routers have mounts on the bottom so you can put them on the wall.  If yours has that then you could mount it on the side panel of your case, or really anywhere else in your case.
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-879522
Mine does, only issue is the power brick, the size o a brick
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-879571
Is the power brick at the wall plug or mid way through the power cable? If your case has those water cooling gromets you could route it through those?
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-879770
Yeah halfway, i think ill try and do the mod in a minute, i have s router sized wifi extender that has ethernet plugs on it
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-879963
Idk maybe it would depend how big the modem is. It would be hilarious though.
just put it in. :)
Haha maybe that will work.
It has been done, can't upload pictured because no camera ATM. But instead of a modem used WiFi extender with Ethernet from extender outside of the case into the RJ-45 jack.
Speeds are better than power line connected straight into modem
30mbps down (my plan)
3mbps up (my plan is not stated the up)
I am impressed
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-880087
I am impressed
Nice! Please upload some pictures when you get a chance so we can see :)
https://linustechtips.com/topic/62427-modem-inside-case-case-mod/#findComment-880353
