The 810 can take a 360/420 in the top. Not sure about the 820, I believe it supports a 360 on the top...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/624-nzxt-810-and-820/#findComment-7648
[TABLE]
[TR=bgcolor: #333333]
[TD=bgcolor: #cccccc]
FAN CAPACITY[/TD]
[TD=bgcolor: #f3f3f3]
Top: 2x 200mm (One included) or 2x 140mm or 3x 120mm
Front: 1x 200mm (Included)
Bottom: 2x 140mm or 2x 120mm
Rear: 1x 140mm (included) or 1x 120mm height adjustable
Side: 1x 200mm (included)
Pivot: 1x 140mm or 1x 120mm internal pivot fan[/TD]
[/TR]
[/TABLE]
So, you can get 3*120, 2*140, or 2*200 in the top
https://linustechtips.com/topic/624-nzxt-810-and-820/#findComment-7675
I have a 3x140mm radiator in the top of my switch 810 but I had to drill some holes. A 360mm or smaller will fit no problem. I believe the 820 has an updated top panel for mounting both 15mm and 20mm spacing 140mm radiators.
i5 2500k, MSI Z77 Mpower, 4x4 GB Musking Enhanced Blackline. MSI N560GTX-Ti Hawk(temporary), Samsung 830 128, Silverstone Strider Gold Evolution 750w
https://linustechtips.com/topic/624-nzxt-810-and-820/#findComment-7795
Think it depends on your motherboard choice as well, depends on the height of the vram heatsink
I'm running a maximus V formula and EK XTX 360 (cant remember the thickness)
and I'm unable to do push/pull with that motherboard
so it all depends on your fan setup choice, I've seen a modder put 2x420 monsta rad in the 810
https://linustechtips.com/topic/624-nzxt-810-and-820/#findComment-8310
Firstly they don't make a monsta in that size they only come in the 120mm variants 120mm, 240mm, 360mm, 480mm. I don't think the case has enough room for 840mm in length or rad. They defiantly do not make fans or rads in that size either. So I'm gonna assume that you mean a 2x120mm rad and not at 2x420mm rad.
https://linustechtips.com/topic/624-nzxt-810-and-820/#findComment-8524
